N
Nmidia
Hi all, first post so play nice!
I am about to start a rebuild of our bathroom. It is stud walls on all sides with plasterboard. The floor is T&G chip board. Due to leaks over the years I am going to have to replace the floor boards. Along one wall we have stud box work covering the pipes and cistern.
We plan to use 10mm thick slate tiles, approx 28kg per m2. These will be a mixture of 300x600, 120x600 and 60x600. On one wall we have some slate split face cladding coming in at 36kg per m2.
My questions:
#Am I ok to completely cover the bathroom in 10mm marmox (walls and floor). The walls and box work will be studs at 300mm.
#Am i correct in thinking that in the shower area I should use solid adhesive, or should I comb it?
#Should the adhesive be 6mm thick?
#I have seen conflicting info about whether to prime the marmox boards, can anyone clarify?
#For the floor, should the boards be glued (using tile adhesive) or screwed? Again, I have seen conflicting info.
#Will the 10mm board support the weight of a wall mounted sink or will I need to build a frame behind it? In the current bathroom the sink is simply screwed to 18mm ply. I am not planning on having anything too extravagant for the sink, I doubt it will be very heavy.
#If I use the marmox waterproof tape around all of the floor level joints under the shower and seal between the joints up the wall will that suffice for tanking?
Thanks in advance for your help!
My questions:
