d438a1
Hi guys,
Just after some advice as will be starting to tile bathroom floor soon. We have bought 300mmx300mmx10mm slate tiles and i just want to run through my plans, so correct me if there are better ways please..
For the floor....
Subfloor is to be 18mm plywood screwed down at 200mm centres. On top of that will go 12mm hardibacker set using Rapidset flexible and screwed down at 200mm centres.
When thats all dry, i was going to use Rapidset flexible again, with a 10-12mm(?) notched trowel and lay the slate tiles. After its dried, i was going to seal with linthoseal (was recommened to me by someone) grout, then seal again.
For the walls...
We would also like to use the slate tiles to tile the bath surround (top and side panel) and also the shower cubicle walls (900mm quadrant). All of these areas have Hardibacker secured to it, apart from one of the shower walls which is the orginal plaster which is in good condition. Can I get away with using a smaller notched trowel for the bath frame or the shower?
Thanks in advance for advice
For the floor....
For the walls...
