- 0
- 486
Evening all
Earlier today i finished installing my warmup UFH mat and covered with Levelflex SLC ready for tiling. Although i spent a long time insuring the mat was well taped down with the loose wire being glued down with a hot glue gun, I have a few areas where it has lifted and is not totally covered by the SLC. Is this a problem - should i add another layer of SLC?
Annoyingly i didn't quite have enough SLC to do the whole room - 1m remaining (supplier told me i had more than enough). Is it ok to apply the extra SLC needed even though the SLC applied has feathered down to the Marmox board i.e 0 - 1mm thickness?
If this saga wasn't enough, the friend i borrowed to help mix the SLC whilst i floated got his calculations wrong and added an extra 1 pint of water over the recommended amount of 5 litres max per 20kg bag :mad2:
Is this going to crack or possibly fail later down the line? - You will probably determine if he's still my friend??? :lol::lol:
