Discuss slc on ufh in the UK Tiling Forum area at TilersForums.com.
groucho
ive recently self levelled over ufh a couple of times but the floor ended up a bit up and down to say the least. which is a pain when it was flat to start with. I used a spike roller mixed the slc a bit on the thick side then rollered it. but it didnt come out that level. which in turn made the tiling harder and slowed me down. both floors looked fine when down but it was a bit of a pain and time as they say is money. was going to ditch the roller and use groat float to try and achieve a flatter floor. any ideas ? which is best method? cheers
charlie1
recently used this stuff due to local mapei supplier running out of renovation screen... it should be renamed as granfix compound....its soooo bad i can't stress this enough. i should have realised when reading instructions ... mix 3.75 (i think) L of water with 25 kg bad... the end result was i floor that had to be re levelled....furious!!
AliGage
Subscribed
4,531
1,188
Peterborough, England
I've just used ultra level-it on a slate floor with UFH i'm doing this week. I think sometimes people misconstrue SLC. Yes to an extent you it "self levels" but you have to trowel it out to help it along. It's sometimes easy to go through the motions of mixing addy as we do it day in day out. I make a point of measuring out the exact amount of water with a cheap plastic measuring jug i carry. OCD i know, but it gets my mind set on the fact it's SLC and not addy so i don't mix it too thick. The stuff i used this week was 4.25 litres to a bag.
Ajax123
1,213
Lincolnshire
They are not really termed self levelling compounds generally these days because as you say they do not self level. They should be more correctly termed self smoothing compounds
John Benton
1,138
Leeds
Tilemaster levelflex is 4.5-5.0 litres of water and 20kg bags...
Just used 2 bags of it myself today used 9l and 2 bags and went over ufh mat in wetroom. It does need pushing about with a trowel. I wouldn't guarantee a perfectly level floor but it will be smooth :thumbsup:
Reply to slc on ufh in the UK Tiling Forum area at TilersForums.com
Hi I asked the Wunda technical department if I can just use a Ditra mat only and not the SLC...
Moved this as I incorrectly posted in the Pro forum! Hi all, Finally getting to lay the tiles in...
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
slc on ufh
    Votes: 5 4.6%
    Votes: 8 7.3%
    Votes: 6 5.5%
    Votes: 30 27.5%
    Votes: 14 12.8%
    Votes: 28 25.7%
    Votes: 3 2.8%
    Votes: 2 1.8%
    Votes: 19 17.4%
    Votes: 18 16.5%
    Votes: 13 11.9%
    Votes: 5 4.6%
    Votes: 3 2.8%
    Votes: 1 0.9%
