Discuss SLC vs Thick bed adhesive in the Canada Tile Advice area at TilersForums.com.
tilemania
i have a job that requires laying 800 x 600 tiles.
weber thick bed adhesive is about the same price as a decent SLC, so why not just use thick bed adhesive and tile the floor level as you go rather than use SLC to level a floor?
it is quicker (i can start tiling today), requires less priming (thick bed adhesive will stick to pretty much anything) and no messing about getting the SLC level and true (which is a difficult task in itself). i think it will be more accurate too as i will be levelling the actual tiles.
am i missing something?
tilemania
thanks guys. you make some good points and it looks like the general consensus is do the prep right and the tiling will be easier.
i guess i find it easier and quicker to directly tile level and flat on an uneven floor rather than level it first, as the levelling is never quite perfect and i find the floor takes just as long to tile even after it has been prepped with SLC.
@ AliGAge, the floor needs on average about 10 - 15mm bed where it's worst (about 1/3 of the floor) and then the rest isn't as bad. in some places (very small areas) it's closer to 25mm but no more than that.
AliGage
Subscribed
4,531
1,188
Peterborough, England
Are these in certain areas then? Like potholes?
Reply to SLC vs Thick bed adhesive in the Canada Tile Advice area at TilersForums.com
Hi I asked the Wunda technical department if I can just use a Ditra mat only and not the SLC...
I've got an AKW Tuff form shower tray with a waste that is 10mm above the tray when fully...
Hi all, Will I be setting myself up to fail if I use the Dunlop CF-03 Flexible Fast Set Tile...
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
