Discuss Slope for Wet Room Floor in the Canada Tile Advice area at TilersForums.com.
10
108
Cork
I posted on this in the main forum but responses although gratefully received are fairly slow coming and I need to make decisions quite soon.
Below is a diagram for my bathroom renovation. New stud walls being erected and new concrete floor.
Question:
Will the slope shown for the tiled floor below be sufficient to stop water being splashed onto the nearby door or going out into the adjoining hallway.
I can live with putting in a half width shower screen on the wall but would really like to avoid putting a raised stepover in the floor.
Are there any guidelines available on this. Will a screen and/or stepover be needed.
10
108
Cork
Thanks for opinions. We can live with that. Do you think screen would have to go all the way to floor level.
Visually I would prefer a screen that would be supported on legs about 10cm high and also sit slightly proud from the wall. Ideally I could find a foldable one supported only at the wall to allow better access. Must start looking at what’s available
10
108
Cork
Thanks for all the pointers. There is good head room so not much restriction on height that screen can be so I just have to make sure it’s tall enough. I reckon I can assess that.
Re flow: I was thinking I would need 20mm per metre fall but I probably need to check that also. It will not be a power shower.
I was looking at the Schluter linear drains and the connection on those willl be the limiter. I can check the specs of that I guess vs the specs of the shower I intend to buy.
Dumbo
Why not get a drain where you can use a 50mm waste
Boggs
1,118
Uk
Most linear drains take a McAlpine trap, they drain around 26l per minute on 40mm waste pipe.
Turbo wastes on 50mm will normally be around 35-40l minute.
10
108
Cork
Just like to say thank you for all the responses above. Much appreciated.
The tiles arrived on a pallet yesterday. Nervous few minutes checking and counting them all out but zero damage and they threw in a few extra for free. Builders should be starting work within a couple of weeks but tile laying will be quite a while after that I imagine. Will post a photo or two at some point.
Reply to Slope for Wet Room Floor in the Canada Tile Advice area at TilersForums.com
We've had a wet room installed upstairs using the Impey wet room system (see attached). The...
gamer1
G
We decided to replace the mosaic floor tiles in our wet room (2m x 2m). I've removed the tiles...
Hello, just seeking some much appreciated advice about tiling over a wet ufh system which is...
Cork
    Votes: 5 5.0%
    Votes: 8 8.0%
    Votes: 6 6.0%
    Votes: 24 24.0%
    Votes: 14 14.0%
    Votes: 28 28.0%
    Votes: 3 3.0%
    Votes: 2 2.0%
  • Tilemaster /Kelmore
    Votes: 19 19.0%
    Votes: 18 18.0%
    Votes: 11 11.0%
    Votes: 5 5.0%
    Votes: 3 3.0%
