Discuss Small glass mosaics - marmox showerlay in the British & UK Tiling Forum area at TilersForums.com.
From PCS
"If using mosaic tiles they should be no smaller than 50mm square. Do not use mosaic tiles if the tray area is going to be subject to high localised point loads, such as wheelchair usage. Tiles of 150mm square or greater should be used for wheelchair usage". - See more at: How to install PCS level wet room kits
F
FWbs
I got the showerlay and marmox board delivered, it is clear to me that i cant use my flat pebbles on it.
i called marmox, they admitted that it is wrong information in that leaflet/pdf above. their advise is to cover the showerlay and board with a 2 mm tile adhesive ,let it set for 24h then tile it. but i dont think that would be a bulletproof solution, my suggestion is to cover the lot with 4mm ply sealed and installed with tile adhesive. they agreed that this would work.
good luck to me
Reply to Small glass mosaics - marmox showerlay in the British & UK Tiling Forum area at TilersForums.com
Hi. I'm relatively new to tiling, and have begun offering it as a service alongside my existing...
6K
anybody got experience of using small mosaics, 25mm or so, on a showerlay tray? Marmox say it's...
mattle40
Hi all , I've jus finished tiling a quite large shower inclosure with glass mosaics and now the...
K
Evening, im doing a bath room refit for a customer, with backer board on one wall , with the...
Hi all First post here so please be gentle! I am about to start on a refurb of our ensuite...
6K
Qwerty
Q
    Votes: 9 5.5%
    Votes: 17 10.3%
    Votes: 12 7.3%
    Votes: 46 27.9%
    Votes: 21 12.7%
    Votes: 39 23.6%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.5%
    Votes: 17 10.3%
    Votes: 8 4.8%
    Votes: 5 3.0%
