Small Tanking Job On A Low Budget
whatnext
I'm looking to help a friend out by resealing there shower tray before they have a more major problem. Ideally I should rip out what is installed and start again but sadly there is not enough money in the pot for that.
The shower is in an alcove, is not tanked and has suffered a very minor leak in the bottom corner where a plastered block wall joins a plasterboard wall. It would appear the grouting between the bottom and second row of tiles failed and luckily the water damage was minimal and easily fixed.
The 795mm square tray is in a 845mm wide alcove so there was a horizontal ledge of tile between the wall and the top of the tray, which I know is not a good idea. I've removed the bottom 2 rows of tiles and the ledge of tiles so that I can put some form of tanking in.
All the tanking kits I can find are for much larger jobs and would mean a lot of fairly expensive product left to go to waste. I have tin of liquid damp-proof membrane (LDM), which I'd like to use, but it would seem that this is no good, in part, because it wouldn't support itself across the gap between the walls and the side of the tray; but then neither does the proper tanking compound.
If I embedded some fibreglass or polyester clothe within several coats of LDM, thus supporting the LDM where it bridges the gap would this be OK? I've stuck a piece of tile coated with the LDM to another piece of tile using waterproof tile adhesive and they are well stuck together; I've been unable to break the adhesive to LDM bond (the pieces of tile shattered first, although with much twisting with 2 pairs of 10" pipe wrenches I did manage to break the LDM away from the back of the tile.
Any help would be much appreciated.
Get some tanking membrane, buy how much you need without having to much waste.
Can you suggest a suitable make and how far up the walls I should take the membrane and what it should be stuck down with? One wall is bare plasterboard (decorating side out) and the other 2 are painted plastered block circa 1935. Would the liquid DPM be suitable to stick the membrane at least to the walls?
Just in case it makes a difference - I think the tray is made of some kind of hard resin composite rather than acrylic. It's 135mm deep and is at least 23 years old, has no cracks in its surface; seems very solid and does not appear to flex.
Many thanks.
Sounds to me like your just prolonging the problems for a little longer. If it's been in 23 years it's probably time to sort it out.
I understand your point but there's not enough dosh to do it properly so I have to find a work around.
Also can anyone suggest suppliers/manufacturers of 40 to 50mm plastic quadrant and/or scotia trim?
Sounds like a bodge. Albeit one with thought to it. Not something I'd do so i can't offer any advice, sorry.
Tanking and Wetrooms
whatnext,
One Day,
whatnext,
One Day,
