Discuss Small tiling job in the British & UK Tiling Forum area at TilersForums.com.
sibs
Hi gang
Went to look at a very small job the other day- 1.4m by half a meter splash back. The wall has 5 plug sockets which are pulled out at the moment (the guy is a spark) and two casings for downlights which he can also pull out so that they can be tiled behind.
The tiles are 30mm mosaic tiles on 300mm sheets calles Montage Quartzite Squares - slate green effect from B&Q. On the box it says they need sealing. Can anyone tell me what these tiles are or if quartzite is the actual name of the stone (excuse my ignorance)? Or what type of stone this is if not and what sealer to use .... it has shiny flecks like glitter.
Also as its such a small area I was going to price it as £100 inclunding mats and sealing it. Does this sound reasonable or too cheep/expensive?
I only ask because every quote I give I never seem to get the job so want be sure I have got my pricing right. Thanks
kilty55
1,113
edinburgh
sibs i always seal 1st as i find if your goin to be tiling walls the sealer simply runs down the walls and that could end in complete disaster if not removed properly also i dont beleive it seals it properly, sealing your tiles flat allows the sealer to soak in /penertrate properly,sometimes i give 2 or 3 coats dependin on what thew stone is taking before fixing anything.cheers mate
Reply to Small tiling job in the British & UK Tiling Forum area at TilersForums.com
Hi all, I'm looking to tile the entirety of our small patio area with either brick slips or...
Hello, Novice DIY tiler here looking for advice please. I'm replacing tiles in very small...
gamer1
Small tiling job
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
