Swindiff
Hi
1st time post, newbie tiler after some advise.
I am planning on tiling the whole of the downstairs in a 3 storey townhouse, total area is around 30 square meters, have ordered 33 square meters of this porcelain tile. The room is kitchen / diner / family room, with a cloakroom and hallway.
Surface White
There has clearly been some water issues in the kitchen area in the past, as far as I can tell the floor is a concrete base (assumed as I cant see it) there is then a layer of insulation (polystyrene sheet), a DPM (blue plastic sheeting), then 18mm T+G Chipboard and then plywood (maybe 6mm thick).
I am assuming where there has been a leak in the past the plywood was compromised as it has been cut away (actually looks like it has been gnawed by a beaver) where it could be accessed in the kitchen area, however the ply still remains underneath the kitchen cabinets and in the dining area. The chipboard is also rotten around the sink area.
My plan is to remove the remaining plywood from the dining area, and where the cabinets once were (the kitchen has been removed). I then need to cut out the rotten chipboard with a circular saw and replace it.
I am then planning on laying 6mm Hardie Backerboard, this seems to be the best price I can find.
HardieBacker EZ GRID 6mm for Floors (HardieBacker 250) | Dry Lining | Plasterboard | Specialist Board | | Insulation Express
I have read that this should be laid on non-flexible tile adhesive and screwed to the chipboard. As the chipboard is 18mm and the backerboard is 6mm, the standard Hardie Backerboard screws at 32mm will be too long and puncture the DPM and Insulation so I was planning on using these screws which are 20mm
http://www.screwfix.com/p/turbogold-woodscrews-double-self-countersunk-4-x-20mm-200-pack/11191
The joints then need to be taped and skimmed with the same non flexible adhesive
http://www.diy.com/departments/ceme...6414!&ef_id=U853pAAABQH6jUcU:20160607105713:s
The porcelain tiles are then laid with flexible adhesive.
Have I got anything spectacularly wrong here?
Are those screws suitable, they seem to make a big deal about using the right screws, but then I guess they want to sell their product.
What adhesives should I be using, flexible and non-flexible.
Many thanks for any advise you can give.
Cheers
Surface White
Cheers
