Discuss someone double check my plan for the next week please ;D in the British & UK Tiling Forum area at TilersForums.com.
wilfredolimb
OK,
UFH is glued down and planning to do self levelling compound and tile shortly after.
The area is roughly 6m2 and includes walkin shower which im putting UFH in also
Is the plan below ok?
1. use studs to block areas
2. use 3 bags of FIBREPLAN pour and level using TROWEL about the same height as UFH cables (2-3mm)
3. Leave to dry
4. use BAL RAPIDSET FLEXIBLE ADHESIVE mixed with MAPEI LATEX PLUS over UFH in walkin shower bit and smooth to falls using TROWEL
5. leave to dry
6. Everything dry, use more BAL RAPIDSET FLEXIBLE ADHESIVE for porcelin tiles
any thing im missing or got wrong here guys?
Thanks for help
Olz
Are you using a shower former or just making the falls yourself.
Dont mix bal and mapei, either use bal and admix or mapei and latex plus.
Mapei is cheaper and better than bal IMHO, my reccomendation would be to stick to mapei mate.
Apart from that sounds good, whats the substrate? The fibreplan is great, wont take any trowelling to level, three bags sounds about right.
wilfredolimb
Mapei is cheaper and better than bal, my reccomendation would be to stick to mapei mate.
Hi Oli, thanks for fast response,
Yes it is a former, tuff2 from wetdecs
ok i'll get admix, niceone!
by substrate u mean what the mat is on? its on no more ply...which i think is wrong? i heard i should've used aqua panel? but too late now ><
cheers mate
Superally
2-3mm of fibreplan in my experience is not enough. You will still have exposed wires. When you lay the mat down bits of it will stick up so use small strips of duck tape to hold down. I found that the glue gun approach took too long. Glue takes a while to hold. You will always need more SLC than you think and it flows pretty easily, so make sure you have enough and maybe keep a bag spare. Last thing you want is to get to the last corner and run out. Good luck.....it gets pretty exciting when pouring.
F
faithhealer
agree Superally, closer to 4-5mm but I found my glue gun to be ok, must be a different glue stick!
Reply to someone double check my plan for the next week please ;D in the British & UK Tiling Forum area at TilersForums.com
I'm embarking on tiling a kitchen, wall-to-wall (under washing machine etc). most of the floor...
We are having some issues with our newly laid tiles. Within several weeks of being laid, we...
David John
    Votes: 9 5.8%
    Votes: 15 9.7%
    Votes: 11 7.1%
    Votes: 45 29.0%
    Votes: 19 12.3%
    Votes: 37 23.9%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.6%
    Votes: 17 11.0%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
