Sony bravia 189 watt tv. Discussion ThreadSony bravia 189 watt tv. Electrical Advice
Hi I recently posted before about a job where the local TV installers had cut the moulded plugs off dvd player,sky box,sound bar,and Sony bravia 2012 55 inch TV and stuck them all into a flex outlet behind tv and switched it from a 13 amp switch fuse spur .I've split them all up now so there all independently fused.the tv is from 2012 but not plasma ,the manufacturer states a 10 amp fuse for tv but I only had a 5 ,tried both wholesalers close by and of course they just keep the basics.went home to see if I could pinch one from my own house but all my tvs are 5 amp including the 55 inch which is rated the same.its a 1.00 flex .do tvs really have a large inrush current when switched on .does a 10 amp fuse really protect a 1.00 flex. Obviously I'll get a fuse online but If I leave the 5 amp over weekend I'd be worried it popped and caused damage .any advice welcome .it's a Sony bravia lcd tv kdl 55hx853 rated at 158 watt
Sony bravia 189 watt tv. for the original thread on Electricians Forums
