Discuss Speed skim tool in the Canada Tile Advice area at TilersForums.com.
Aston
Cheers guys, I got a few hundred metres of slc to do so I think I might get one then.
I take it you use your spiked roller and then finish off with the speed skim?
Spot on,
Pour, spiked roller and then a quick steady glide over the surface with the speed skim ;0)
If it's a big floor, get the 1.2m version with the pole adapter.
H
hmtiling
Spot on,
Depends what stuff you're using. Some fibre modified ones don't recommend a spiked roller
Reply to Speed skim tool in the Canada Tile Advice area at TilersForums.com
Hi I asked the Wunda technical department if I can just use a Ditra mat only and not the SLC...
Moved this as I incorrectly posted in the Pro forum! Hi all, Finally getting to lay the tiles in...
Hi, 1st time tiling, decided our ensuite would benefit from being a wetroom. Quick question, any...
Wiltshire
Speed skim tool
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
