mattyg
Ok guys.
I'm starting the building prep on my bathroom this week, ( well myself and my bricky cousin )And I'm after some tips tricks Ideas or just the correct way to do it.
Here's some pics to get us started.
1:
Bathroom 1 by mpg Photo's, on Flickr
The unit on the left is staying but moving over to the right a bit. The wall with the towel rad is going and is to be replaced by a glass partition/wall floor to ceiling
2:
Bathroom 2 by mpg Photo's, on Flickr
The Bath is being brought out to approx the same as the old chimney in the left corner. Unless we can remove it easily (not used and is full of cavity insulation) That should mean we can get the bath central (that'll help with the wife's OCD)
3:
Bathroom 3 by mpg Photo's, on Flickr
Thats the stud wall being removed and replaced with a glass partition. Got a few questions to ask about that. (could be a costly cockup)
4:
Bathroom 4 by mpg Photo's, on Flickr
The minging shower. Last tiler did a crap job not bad at setting out but he aint getting another tiling job from me. :lol:
This is going to be a wetroom type of enclosure with a preformed wedi floor thingy.
Not the biggest of bathrooms. But we should be able to squeeze everything in.
Ok so Tuesday skip is coming and ripping out.
All taking back to brick. (original plaster from 1895 ) should make the bathroom a foot wider and longer:smilewinkgrin:
Floorboards coming up (winters coming and have a woodburning fire)
Noggings being put in to strengthen joists (bit of bounce) Then lay18mm WBP. Weve been advised to use acrylic primer on the Back?? and sides leaving 2mm perimter gaps and fill flexi or Silicon.
Then lay 10mm insulation boards before electric UFH. And self level finally install 'Schluter Ditra' De-coupling membrane.
The wall are to be boarded using foil backed plasterboard most likely dot'n'dabbed not sure enough room or flat enough walls for a thin stud.
Shower wall to be boarded with marmox or Wedi waterproof backer boards
Ceiling is also being replaced and re skimmed.
The plasterer wants to also skim the walls. Incase we ever need to re tile we may end up reboarding.
However I dont like the Idea of waiting 4 weeks to tile afterwards. were not having heavy tiles so the hanging weight wont be an issue if we skim. But chances are even with only a skim it'll be flatter without.
I think thats it for now.
If I'm off with some details guys help me out.
I'm gonna need some guidance along the way especially when it comes to the wetroom part.
Thanks in advance
Matt
1:
2:
3:
4:
Thanks in advance
Matt
