Discuss Still having a problem with granite tiles in the British & UK Tiling Forum area at TilersForums.com.
shirleyali1
Hi to all
Hope some of you remember me, just to say we are still having a problem with the black galaxy tiles laid in the conservatory.
They were laid and sealed in one day. A few days later another guy came and sealed the tiles on a red hot day. He sealed about 18 sq metres in less than 20 mins. told us to shut the door and leave them till the next day and then wipe off the surplus.
He also asked for the payment in full, which we stupidly did without cleaning off the sealer.
Anyway after cleaning the floor the tiles were all streaky. We phoned up, and he reluctantly came up to look at them a week later, on another hot day and sealed them again. Telling us again not to walk on the floor till the next day and then clean the floor.
Floor even worse.
Man was very abusive, said he wouldn't do anything else.
So we got another firm in who were recommended to us. They said the sealer should not have been applied in hot temperatures and had baked on the granite tiles. They recommended stripping back the tiles to remove the excess sealer.
When they did this a lot of black mess came out, and now the tiles are a lot lighter. It seems the tiles were probably dyed.
Could somebody tell me what the best course of action is now. The tiles are a complete disaster. Can you dye them back? the stains are still there as well and run through severall tiles.
Just wished we had not paid up so quick, learned a hard lesson.
:mad2:
MICK the Tiler
Some stone including granite can suffer with a problem we call down here mirror transfer, this is where moisture or trowell marks stains in the substrate can bleed through to the top of the tile from underneath. This may be the problem you face and as the tiles were laid and sealed on the same day might give this theroy some credability as what the fixer has done is seal all exit points for moisture in the addhesive and grout by not allowing the proper curing time and as a result the moisture has no where else to go but up into the tile itself and forming streaks on the surface. Stripping back the sealer and reapplying did not get rid of the streaks another tick for the bleed through theroy. I live in sunny Queensland and it gets pretty hot down here and I have no problems with sealing in hot weather, although I have to work alot smaller areas to compensate.
This suggestion is just that a suggestion and a few pictures of the problem area would indeed help with a complex problem which this is.
TilingLogistics
Hello Shirley
I do not wish to insult you but can you Please confirm you have Star Galaxy Granite and not a Basalt copy granite!
Secondly can you tell me what make the sealer was that the tiler used?
What did he strip the tiles with?
Where are you in the Country please?
If you can answer these questions and post some pics I may be able to help:thumbsup:
Kev
TilingLogistics
Isn't star galaxy a composite granite - resin based? If so, the lightening could simply be grout stain (grey).
Might be worth a really intensive clean and start again?
Black Galaxy is mainly found in India the variation that has bronzite (Gold Bits) in is called Star galaxy. However it is produced in relatively small quantities compared to other natural stone and therefore not all importers/retailers are selling the real thing:thumbsup:
Kev
Dave Ramsden
I remember fitting Star Granite before and it was real hard work!
Because every tile has to be run through a wet cutter or cut with an angle grinder the tiles need to be totally spotless before grouting.
We sealer off the doorways with plastic sheeting, washed and dried the tiles. After applying a coat of sealer it was left for an hour the wiped down thoroughly, grouted, cleaned three times then sealed.
The end result was perfect but I haven't got any pictures Im afraid.
Its alot of work to get it right but its so worth it in the end.:thumbsup:
shirleyali1
Hi
Thanks for all your help. We live in N. Staffs.
I did contact the tile company & they said they used Glenstone sealer, which they buy in big drums.
They have since been stripped with a Litholin product, but I don't know which, (have left a message on answer phone for him to let me know). Stains still haven't come out.
Very difficult to photograph, due to reflection from conservatory roof, but will try.
The problem we have is we could be paying to have tiles sealed and repolished again and still be left with stains. Now diamond grinding has been mentioned, which will cost even more or retiling over the granite tiles.
The ironic thing is the tiles looked fine until they were sealed the wrong way. (Red hot day & told to leave it on till next day, with all windows shut)
Any advice will be much appreciated.
Shirley
TilingLogistics
Hi
Shirley
Shirley,
Firstly, sealing should be done sparingly allowing a dwell time as required for penetration then the excess cleaned off. I have never heard of any sealer being applied and allowed to be left over night in my life. Furthermore, I have never encountered problems with sealer in hot weather and I have applied it in Spain in 38 Degrees. The only thing that rings true is all windows and doors should be shut when applying sealer as you want it to penetrate and not dry on the surface.
I grind , hone, polish and seal stone nearly every day and I cannot understand why Diamond Grinding has been mentioned it would not be required unless there is lippage on the tiles. The most it should require is a stripping , repolish and resealing.
I have no experience with Glenstone sealer and therefore cannot comment however, if the tiles looked fine before sealing then surely it is down to the fixer/supplier to sort the problem?
The only other explanation I can offer is as I said in a previous post are you sure you have Granite and not some sort of basalt?
My telephone number and e mail are in my signature block if you wish to discuss the matter in greater detail!
Kev
shirleyali1
Thanks Kev
The problem we have is the tiler refuses to do anything about the tiles, he has written to say so. He has been paid in full, which was the biggest mistake.
We had to have another company out, who tried to remove the baked on sealer. The stains go through several tiles, so we know its not a natural feature of the tile. The new tiler will have another go at removing the sealer, before he seals and repolishes, but we are afraid that it still won't come out and we have incurred even more cost.
Hopefully we can claim the cost through the small claims court.
Regards
Shirley
Reply to Still having a problem with granite tiles in the British & UK Tiling Forum area at TilersForums.com
We had a wet room fitted by a large company. We have issues with a few large steps where the...
Looking for some technical advice on these tiles please. Our installers fitted this CaPietra...
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
