Discuss Straw walls in the Canada Tile Advice area at TilersForums.com.
That's what I can't get my head round the fact there's no studs to fix to.I've done a couple, if the walls need repairing it's a case of just priming and using rapid set, if they need reboarding the boards have to be stuck to the original surface as there are no studs in them, or at least the ones I've done haven't had.
I have to strip the old tiles off .....so if it needs re-boarding what do you use to stick the new board on ?
Reply to Straw walls in the Canada Tile Advice area at TilersForums.com
