D-Eye-Wire
Hi all,
(I have tried looking but could not find this subject covered in another thread, if I am mistaken please point me to the correct thread and I will try to cancel this posting)
Replacing a small 3sqm washroom with a wetroom, and contemplating the use of Hardie's 22mm structural board HardieFloor (Structural Fibre Cement Interior Flooring - HardieFloor in a bid to achieve levelling with existing floorboards in the neighbouring room and the 22mm Impey WetDec former. Would most appreciate some advice with the following:
DOES ANYONE HAVE ANY EXPERIENCES TO SHARE OR RECOMMENDATION ON REGARDING THE PRODUCT AND PROPOSED APPLICATION?.
The plan is to:
ANY OTHER ADVICE or highlighting of MISSED STEPS WOULD BE APPRECIATED.
Given the small area I intend to waterproof full length of all walls. but as yet have not decided on which route to take. e.g. hardie or aquapanel with membrane or Wedi/Marmox setup.
THANKS IN ADVANCE
The plan is to:
- strengthen joist work (trimmers/noggins screwed with 10*4 or 12*4 Spax quality screws).
- lay insulation between joists ANY RECOMMENDATION ON WHICH INSULATION. 2a) Replace an existing AAV heading into the attic with a A1 AAV raised to 200mm above the highest wet entry's centre line - this AAV will fit within the joist space.
- Fix HardieFloor - (Spax quality 50mm screws at 100-200mm intervals, 25mm from T&G edges, 12mm from butt edges + gripfill type adhesive on joists and silicone sealant on T&G ends and screw heads).
- Apply tanking membrane (preparing HardieFloor according to chosen tanking system e.g. priming)- was planning on using Impey's Tilesafe but given its vertical tile load and heating limits I am looking for alternatives - perhaps Impey's Waterguard, I will be going through other threads on this forum to understand different tanking membranes.
- securely fix RCD protected UHT (compatible with the chosen tanking membrane) ANY RECOMMENDATIONS FOR UHT SYSTEMS?
- consider applying (depending on the robustness of the UHT mats) SLC for general floor area and slurry of rapid setting flexible tile adhesive on former tray.
- Lay tiles with flexible adhesive and grout that are compatible with the chosen membrane system.
THANKS IN ADVANCE
