Sigma UK
There will always be some tiles it just won't cut. Mainly anything with a thick glaze on top. (wet cut only). Are you using the 20mm strips or just trying to cut 20mm off the whole tile?.
I have never not cut porcelain dry
Only ones I struggled with had a glass face
Thanks @Dave for this original advice and to anyone else who can just give a wee bit more clarification on this adjustmentJust to add , make sure you set handle depth to suit tile depth , this makes full use of the breaker ... 5mm from rail to handle runner.. Then score nd put breaker foot about an inch in and sharp quick wack on the handle to shock the tile and if you have set the depth correctly , then no chance of crushing the tile no matter how hard you hit the handle.
a common mistake is not setting the cutter to suit tile thickness , a big advantage of the sigma over any other machine.
