Guitardedleon
starting to get somewhere with this bathroom Ive had planned.
so far I've:
Replaced door and lining.
removed all the old tiles
removed the old suite
removed the lino & tore up all the floorboards
re-plumbed
new electrics for heated & lighted mirror and IP65 spots I've had installed.
strengthened the joists and installed noggins
Ive also ply lined the floor , 25mm wbp primed on back and sides with SBR.
screwed to joists at 150mm centers.
however,along the one long edge is a lip of between nothing up to 2mm at the worst point.
this is a join going at 90 degrees to joist direction.
I plan on using a Ditra matt under the tiles.
is this lip ok?
thought it would go when screwed down, but can not fix it.
thanks in advance
so far I've:
re-plumbed
is this lip ok?
thanks in advance
