substrate question
Spud
got a 45 sqm floor to lay on a 25mm modified sand and cement bed with chicken wire mesh reinforcing, 900x450 porcelain drop lay method ,subtrate is a fibre screed 40mm thick over ufh, the substrate is showing cracking which i was going to repair with the epoxy resin and steel pins repair method, the floor is on block and beam construction over a basement with insulation then ufh then the screed but it is showing signs of movement ,as it is unbonded do i decoulple the floor using a cleavage membrane or do i bond it to the substrate in hope it will tie the floor togethr with the slurry and chicken wire and give it the required 60mm over the ufh ? any advice appreciated
I'm with jay on that one, a decoupling membrane to keep it seperate from substrate.
I would have thought the fibre screed would have been 60mm at least
I'm really not keen on this type of construction, I don't know why considering that a lot of continental buildings use this method and they tile floors a hell of a lot more than us. I just think there is too much room for movement. Laterally. So a cleavage membrane would be essential IMO
unfortunately its not, there was 4 tons of building materials stored on the screed which has assisted in creating the cracks, now you can feel the movement when walking across the floor so i am in 2 minds whether to tile it or not ,repairing the cracks will strengthen the floor a bit but will it be enough to take the weight of the new flooring ?
Thats an excesive amount of weight on a block and beam, would the insulation have been pressed down with the weight of materials over a time.
I feel I would back off, I can't give a definitive answer to the problem though
Actually this thread could answer a question that has been going round my head for some time...
Do buildings expand and contract at the same rate between 0-20 degrees as 20-40 degrees and how much does humidity (water content) play a part in this?
Specifically concrete structures (but timber and brick construction would be handy to know)
So for example, if you draw a graph would it be a straight line or a curve?
This might explain to me why certain methods work on the continent and not in the UK.
I might have to wait for the human wikipedia that is Ajax to give me a full explanation on this one!
Hi Gary, I don't know all of the terminology that you and the rest of the guys have used in this thread, but one comment I have is that the conventional wisdom here in the US and Canada (the "standards" as they are being determined by the Tile Council of North America)is that a wire-reinforced unbonded mud bed should be on the order of 2" thick (50 mm). They tell us if we are doing a mud bed that is only an inch thick then we should bond it (to masonry substrates) or use metal lath (fastened to wood substrates) that is placed on the bottom of the mud bed.
thanks rob thats kind of confirmed what i was going to do as the bed thickness was thin ,I had another look at it today and I am now more confident than previously that repairing and bonding will work :thumbsup:
here is what i am doing with the substrate ,repairing the cracks with epoxy resin and steel pins ,the cracks are cut out with a 4" grinder then pins are put in every 6" across the crack and then filled with epoxy this makes the repair stronger than the original screed
I didn't realise it had cracked that much
It that what your finger looks like Gooner?
follow up pictures of problem substrate ,expanded metal mesh was placed through the mortar bed which varies between 40-50mm ,sbr bond was added to the mortar bed and bonding slurries ,60x60 porcelain centre feature with a 10cm border and a 90x45 field tile
So what is that room for? Front room?
What mix is the mortar?
How far is the ufh under the tile?
Is that your bum in the picture?
If so, would you like me to get you some knee pads for Christmas
and lastly... Am i asking too many questions?
entrance lobby, 7:2 polymer modifed,between 70-80mm ,no and I have knee pad pockets in my trousers, and no you can never ask too many questions :thumbsup:
grouting done ,flexi grout ,just the downstairs loo and mat well to do in this method now
Nice work, Gary. It looks like you floated and set all in one shot. Do you have a mixer? We use a mud box and chop it with a hoe.
For small amounts of screed I use a plasterers bath mixed with an old belly drill, very slow mixing and with the right paddle
This room still confuses me, if it's an entrance hall, where is the entrance? is it the door with the fire closer on it? or have we just not seen the main door yet? For an entrance hall that size the door doesn't look grand enough.
Sadly I don't think the pictures do the floor the justice is deserves I know in the flesh and an overall scale would look great. Stop being a tiler, get off your knees, and show us the job in it's full glory:thumbsup:
its only part of a much larger floor area about 250m inside the ground floor which follows through to a terrace of about 75m with steps down to the garden, there are marble skirtings and architraves to be fitted everywhere and marble door thresholds to the entrance floor ,there is a full marble staircase from the basement to the loft ,8 bathrooms , 2 kitchens,utility room, a laundry room, swimming pool and gym,a 250m polished porcelain 60x60 floor in the basement, i am finishing the job next week. i will take a video tour around and post it when i am done :thumbsup:
That looks a great job must have taken some time the only question i have is that some people will say that using EML reinforcing in the morter bed above UFH can cause it to expand and contract at a differnt rate than the bed causing movement problems, ime not sure that wet UFH systems get hot enough to do this but i have heard these concerns raised before, anyone got any thoughts on it .
Lucius
substrate question
Spud,
lucius,
Spud,
lucius,
