Guest viewing is limited
Discuss suitable adhesive, grout and sealer for marble tiles. in the UK Tiling Forum area at TilersForums.com.
charlie101
Hi all
I have a couple of questions on adhesive, grout and sealer for marble tiles. I'd be grateful for any advise you can give.
I'm having my bathroom tiled with 300mmx300mm10mm bianco carrara tiles approx 30 mitres.
The wall tiles will be polished, the floor tiles will be honed and there is a slab cut sink/vanity top which will also be polished.
ADHESIVE QUESTION
1) Which adhesive would you recommend for the wall tiles?
BONDING SURFACES:
Most of the walls are covered with Knauf cement boards but one wall is brick, rendered with cement.
The bathroom contains a shower which will be lined with wetdecs Dura wp tanking membrane and then fully tiled.
GROUT QUESTION
2) Whch grout would you recommend for the wall and floor tiles?
SEALER QUESTION
3a) Which sealer would you recommend for the wall tiles, floor tiles and sink/vanity top?
3b) When to apply sealer
The company providing the marble say that most marble fixers like to fix the marble and then seal it because it's easier to do it that way. However, they recommend sealing the marble before fixing.
Specifically in relation to the tiles they recommend sealing the front and all edges before fixing and then leaving the surface ungrouted for a period ( I think they said 1 week) to allow the adhevsive to give up its moisture through the joints instead of the (now sealed) tile surface.
What are your opinions on this?
4a) How many coats of sealer would you apply or is there some way of telling when it's had enough?
Note: I've read Dave's posting on 'Porosity' (LTP) which seems a very sensibly test to carry out. However I'm not sure how it might apply if sealing at the pre-fixing stage?
4b) If the tiles are to be sealed before fixing is this something I could do myself or are there issues with applying the sealer.
Many Thanks
Charlie101
DHTiling
Hi charlie.. i will answer below..
Hi all
ADHESIVE QUESTION
Kera quick white
BONDING SURFACES:
Surfaces are great.
GROUT QUESTION
Mapei ultra colour great for stone as it is fast setting to avoid picture framing affect.
SEALER QUESTION
Aqua mix Ultra-solv.
They are talking silly.. to leave it that long for moisture to escape then they are talking dispersion adhesive and this is no good for stone work, needs to be a cement based adhesive like mentioned above and this dries by hydration( chemical reaction).
1 coat before grouting and 1 coat after, then do a water porosity test to determine if it needs another but with Aqua mix sealer i very much doubt it.
You can fix the tiles and seal them on the walls..
Many Thanks
Charlie101
Reply to suitable adhesive, grout and sealer for marble tiles. in the UK Tiling Forum area at TilersForums.com
    • Friendly
I'm having a nightmare trying to establish product info from distributors. For example...
