Deleted member 1779
Do you need to drill holes in very hard porcelain tiles?
Do you want to do it with ease, using the right tool for the right job. 365Drills are tile drilling specialists and this year (2016) We totally revamped the range for you. As well as the value for money basics range we also have some rather nice looking box sets.
We always did box sets but this year we felt it time to give the range a refresh.
So you will notice we now offer THREE diamond core tile drill box sets (not two)
They are designed for specific jobs. Here is more detail:
Based on the best selling bathroom fitters kit this all in one solution covers your bases for the common pipe sizes to be found. If you need to drill holes for 15mm pipes, 22mm pipes, shower head and basin waste then this is your set. Great value for money. Comes with ALL TOOLS : Nothing extra at all to buy.
And there are loads (7) of drills for rawl plugs too.. !
Now we look at the premium. Some of you wanted a few different cores so this has the best of the rest.
18mm (for 15mm pipes) 25mm (for 22mm copper) 35mm (for monoblock and shower) and finally 45mm (For BATH waste) Plus of couse a selection of small cores.
Want EVERYTHING ?
Try this.... The ULTIMATE
Yes 30 drills in a case. Gulp! The biggest being the 115mm for the 4 inch (110mm) soil stack.}
Wow you can really drill holes into hard porcelain tiles with the big 115mm diamond core drill.
This is for serious installers who want to get the job done, pack up the set [Its a hefty 4kg]
OK finally lets talk about the overall 10 year best seller the Bathroom Fitters Kit. Not a box set but still worth a mention. Everything you need but in the basic presentation. If you dont want a suitcase then this is the set for you.
The drills are just as good as the box sets (they are the same) but less packaging = less cost.
Want EVERYTHING ?
