BigSid
Hi,
New to the site, but been lurking for a while and I'm after a bit of advice about timber floors. I'm in the process of converting my bathroom into a wetroom. It's a first floor bathroom with a timber floor, approx 3m x 1.7m with joists span the shorter distance. My house is a bit old and wonky, so I'm ripping up the entire bathroom floor (as it slopes towards the door) and levelling it out by battening the tops of the joists.
I've bought 18mm T&G spruce floorboards to put down and sheets of 12mm WBP ply to overlay, on top of that will go an Impey Waterguard tanking membrane and then tiles.
However, the wetroom tray I bought is the Impey Aqua Dec Easy Fit and it's 22mm thick, so I need to put something 8mm thick under it to bring it up to the level of the new floor (18mm T&G + 12mm ply), but you wouldn't believe how hard it is to find something suitable that is 8mm. Ply is like 5, 9.5 or 12. I did look at using 4mm Marmox backer boards doubled up, but the only place I could find them would only sell me 10 minimum and I'd only need 4...
I'm wondering now though, whether I should get shut of the T&G and ply and get Wickes 22mm p5 moisture resistant chipboard instead. Thoughts?
