Discuss Tampered floor & ditra? in the Canada Tile Advice area at TilersForums.com.
Hi guys.
Got a job in 2 weeks which requires Ditra. builder has tampered floor quite hard so the floor is no way near flat enough for matting...
What do we do in this instance guys?
I personally would prime concrete slab, thin layer of SLC to flatten it out, then matt it.
I would do the same but make sure you give consideration to the finished floor height...
Thanks Alan, the finished floor high isnt a problem, the area to be tiled is stepped up from the rest of the house.
Cheers mate.
Reply to Tampered floor & ditra? in the Canada Tile Advice area at TilersForums.com
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
Hi - I ripped up laminate flooring on a concrete subfloor. It was my first DIY project and...
    Votes: 6 4.7%
    Votes: 11 8.5%
    Votes: 8 6.2%
    Votes: 37 28.7%
    Votes: 16 12.4%
    Votes: 31 24.0%
    Votes: 3 2.3%
    Votes: 2 1.6%
    Votes: 19 14.7%
    Votes: 18 14.0%
    Votes: 15 11.6%
    Votes: 6 4.7%
    Votes: 3 2.3%
    Votes: 2 1.6%
