Discuss Tanking failed AGAIN in the Australia Tiling Forum area at TilersForums.com.
has the plaster work been polished by the plasterer?
Peeling is not normal!!! How can that ever be normal?
Spoke with the Mega rep yesterday, he assures me that the peeling is normal,
as long as it's not falling off and it has some resistance, also in the colder months it could take longer to dry out.
ive re checked it and yes it has bonded better but still not sure about what the rep had said
1 wall is an external wall but I used gypliner and Kingspan in between studs to create a thermal barrier and decouple plasterboard from external wall,Was a bonding coat applied before plastering? If so, this will extend the time moisture needs to escape before covering it over; up to 2 months depending on the depth of the bonding coat and plaster and temperature.
I suspect that moisture is trying to escape, thus de-bonding the covering you are placing prematurely on it. Is it an external wall? (if so, you may have damp/condensation issues which will cause de-bonding)
Hope this helps.
Reply to Tanking failed AGAIN in the Australia Tiling Forum area at TilersForums.com
