Discuss Tanking GTEC Aqua Board & Formed Screed Floor in the UK Tiling Forum area at TilersForums.com.
AndyH747
Hi All,
I'm about to prepare a shower area in a new build for tiling. The floor of the shower area has been screeded with sand/cement mix on top of UFH. The screed has been formed to slope towards a screed drain. The walls of the shower are GTEC Aqua Board on studs. I want to tank the whole floor area of the shower and up the walls using BAL WP1 or similar.
A few questions I hope the experts can answer:
1. What do I need to to prepare the screeded floor with before tanking? The rest of the ground floor is liquid screeded and they supplied a sealer for this. Can I use this sealer on the screed and then tank on top?
2. What primer is required, if any, on the Aqua Boards? The boards come to floor level and meet the screed so I intend taping at this point with the BAL kit.
3. I was only going to tank half way up the walls of the shower as going to the ceiling seems a bit overkill. What are the recommendations?
Thanks in advance.
AndyH747
It's not made by Knauf it's made by Lafarge GTEC. Knauf's product is Aquapanel, Lafarge's product is Aqua Board. The guidance from Lafarge is that it only needs primed but they can't comment on how other manufacturers tanking products work. That's why I'm asking here to see if anyone has tanked onto either Knauf Aquapanel or Lafarge Aqua Board. The manufacturers have not been very helpful up to this point.
AndyH747
Andy are you sure you want advice from the forum? we are trying to help you as much as we can. What is it that you specifically need to know?
Aqua panels do not need to be tanked, you should do as I suggested in my first post.
Yes that's why I posted but it appears you were unable to advise. You are in a minority that doesn't think it needs tanked. As has been stated the Aqua Board is NOT waterproof, only water resistant.
The question of whether to tank or not is academic as that's what I'm doing. What I was asking was the preparation required on the Aqua Board before applying the tanking substrate.
I'll take the advice of the other posters and tank as recommended. Thanks to the other posters for answering my query.
diamondtiling
Just looked at the Lafarge aqua BOARD website and they are indeed different to aqua panels so you have my apologies, I should have checked earlier.
Just one question then, why would you choose to use a board in a wet area that clearly is insuperior to aqua panels? It cant be used on floors and it needs tanking? Seems like a complete waste of money and time.
Lafarge Aqua Board - Ask the Experts
Ajax123
1,213
Lincolnshire
I would have thought that's obvious.....
I disagree......It is far from obvious......I have had the debate many many times. As far as I can see the two are synonymous terms. In order to make something water resistant you waterproof it. For a material to be waterproof it must be water resistant.
I do know a little about flowing screeds......Supaflo is not anhydrite unless you are in Ireland??
No offence intended by the way :)
DHTiling
Water resistant is when a product will not break down in contact with water and water proof does not allow any water to enter it.. water resistant boards will wet up and soak in moisture but not fail.. as in fall apart like gypsum plaster boards can.. Waterproof boards will not allow water to soak in and through them.... the surface on Marmox type boards will become wet as the cement face wets but the core of the board will not allow the passage of water..
So yes water resistant is different to waterproof IMO...
sam_b
Morning andy
The lafarge boards are great and can be tanked over no problem.
Prime the Walls with APD and leave to dry and then 2 coats of WP1, leaving to dry between coats and yes taping internal joints and wall to floor transitions.
Can i just ask , is this an anhydride screed ? If so , who's
Sent from my iPhone using Tapatalk
Bit of an old post to resurrect but hey.... the tanking kit I was looking at (Megaproof Waterproof Tanking Kit) comes with SBR primer, is this fine to use as well, as opposed to the APD primer mentioned above....
Thanks,
Sam
Reply to Tanking GTEC Aqua Board & Formed Screed Floor in the UK Tiling Forum area at TilersForums.com
TF Group Please Join
