White Room
Why not run a vertical bead of Silicon behind the tiles as you fix where the shower frame will be.
Julian I've asked this question previously & it was stated to let any water flow back out into the tray then there must be weep holes in the bead of Silicon at the bottom.if can throw something in the mix here 😉
you have tanked the shower, it's corners and it junction with the tray perfectly. For whatever reason water gets behind tiles, the substrate is protected.
where does the water go?
a hole would be logical if there was no threat of water being sucked in.Julian I've asked this question previously & it was stated to let any water flow back out into the tray then there must be weep holes in the bead of Silicon at the bottom.
