Discuss Tanking questions in the UK Tiling Forum area at TilersForums.com.
Meek
Hello everyone
Our bathroom has a bath with a shower mixer tap. Unfortunately the bathroom floor's been overlaid with ply (sealed on back and sides with acrylic primer) and tiled without tanking. Would this be a problem in a room with a bath rather than a shower tray? Would moisture still potentially wreck the ply even though the back and sides of the ply have been primed? If so, I might get the tiler to grout the floor with epoxy to minimise any potential probs.
Also, how should I go about tanking the walls around the bath using a tape and liquid primer (weber.sys protect) - should the tape go on the bath lip like it does on a shower? There's a window above the bath, should that be tanked and taped too?
Thanks for any help
oops, thanks for moving the post to the right forum!
Reply to Tanking questions in the UK Tiling Forum area at TilersForums.com
I am sure someone will know a good practice solution. We started a wetroom last year and then...
Hi there, long time lurker, first time poster. I’ve recently moved in to a new build property...
This is a proper newbie question. I've tried to find the answer already provided on the forum...
Tanking questions
