Discuss TEKCEM FIBRE what needed to porcelain tile in the America Tile Forum / Advice Board area at TilersForums.com.
hello new here but wished i had found and asked before screed and ufh down but here goes.
We have an extension (9m by 6.2m) which has a standard slab been down for 4 months, and then insulation in quick drying screed, the existing part has a slightly friable slab with approx 20mm of latex self levelling screed, then low profile ufh in TEKCEM fibre over both new and old. Ive commissioned the ufh as per tekcems instructions. The ufh people had allowed 15mm for 10mm tile and adhesive to take it upto bifold thresholds and no mention of anti frag mat, tiler said he would advise putting one in.
Any advice intending to put in 1200 by 200 10mm porcelain planks.
ps girlfriend wants me to shell out for professional but budget tight could a pretty good diyer lay this to ok standard?
You can give it a try. 1200 by 200 10mm porcelain planks are a pain to install. You will need a perfect screed/slab, embed them 100% in a good tile adhesive. Follow the manufacturer instructions, offset the joints as recommended. It can be done!
cheers any thoughts on need for frag mat and have seen they are 0.7 to 0.85mm but i believe set in adhesive so thicker? If i put in mat how much depth does it take up, i would need to fit it all in 15mm?
Dave
Subscribed
389,925
1,000,000
Co.Durham
Personally, i would recommend an anti-crack mat with a heated screed . Thus preventing any future cracking from transferring to the tiles and with a floor of 9 mtrs in length then it will help with lateral stress. Ditra is my choice of matting.
Anti crack membrane is 3mm thikness
Durabase Uncoupling Mat​
thanks am i right then in saying no room for mat, 3mm uncoupling, minimum 3mm tile adhesive and 10mm tile? Or does the mat allow for thinner adhesive? If cant fit mat what are my options to minimise risk?
Dan
Admin
5,089
1,323
Staffordshire, UK
I'm not sure it's suitable for all cases where decoupling membranes and anticrack mats although sound the same aren't for the same circumstances all the time. I'll have to check tomorrow.
But you cant spare 2mm? Your floor is going to undulate more than that itself.
Dan
Admin
5,089
1,323
Staffordshire, UK
yes will undulate but would like to make sure i can fit level or lower than bifold threshold, ive now gone all along the threshold and the depth to latex screed with ufh in varies from 15mm to 18mm only little bit at one end 15mm, i thought maybe i could sand that down so i have at least 16mm all the way, then could i fit dita 3mm laid depth?, 3mm adhesive? and 10mm tile, or if bal is ok i wouldnt have a bit more room?
Reply to TEKCEM FIBRE what needed to porcelain tile in the America Tile Forum / Advice Board area at TilersForums.com
gamer1
G
hats67 - Yesterday at 11:48 PM Add bookmark #1 Hello guys. I came upon and registered with...
  • Locked
Hi guys A little advice if possible I have a bathroom 2.6 x1.9 on joists 18” gaps New weyroc...
USA Tile Forum Popular
America Tile Advice Trending
SO31 9GB
What member type are you?
  1. DIY Wall and Floor Tiler
    Votes: 5 4.5%
    Votes: 8 7.1%
    Votes: 7 6.3%
    Votes: 32 28.6%
    Votes: 14 12.5%
    Votes: 29 25.9%
    Votes: 3 2.7%
    Votes: 2 1.8%
    Votes: 19 17.0%
    Votes: 18 16.1%
    Votes: 13 11.6%
    Votes: 5 4.5%
    Votes: 3 2.7%
    Votes: 2 1.8%
