Textured tile grout problem
F
Frazer Gould
I recently purchased some black floor tiles from Topps and have grouted them with a grey grout. The tiles are riven but also the surface is non-slip (matt finish). I could not see the problem as I worked but in a couple of awkward places I didn't remove all of the surplus grout (I thought I had but with using a damp cloth the tiny holes filled with grout were not easy to see). Now it has dried the small pin pricks of grout are visible. I have tried vigorous rubbing with a sponge, green pan scrubber and even a brass brush (started to leave brass on the surface so did not pursue that one!). Any ideas how I can remove this problem?
Grout haze remover. Read the instructions and follow to the letter it is an acid based product . Topps will sell it although topps range of fila products is a fit range . You may be better of going to a local tile shop .
I found out about this cloth from my customer after a bathroom install. I originally thought I had a leek.
Amongst the replies to my original some of which were more funny than informative (not complaining) and given some had found useless products I thought this humble DIY'er might tell what I found. When in doubt I asked British Ceramic Tile for their advice and they sold me a product from Tileasy - Residual Grout Remover. It has 10% Hydrochloric acid and it works perfectly. I diluted it 1:2 parts water - no more residual grout. Given the relatively high concentration of acid the usual precautions should be taken. Thanks everyone.
Frazer Gould,
Unused Account 1,
Frazer Gould,
Unused Account 1,
