The Best Outdoor Adhesive?
Sporty
Hi there
I'm going to need an outdoor adhesive that is going to hold down small marble tiles in a patio area. The marble tiles will be laid on a cement screed.
Best options for an adhesive, please? It's obviously got to withstand the weather.....
Cheers
Simon
Hi guys
That's the adhesive I need then is it Tom?
The only place I know of is Topstiles. That's the go to tile shop that I know of....Dave
As for falls, there is a. Slight one heading towards the gully. I screeded a four and one mix in the patio area, ready for my marble. I did that last summer so obviously, apart from a sheet, is open to the elements for the winter. It looks to be holding up ok, even though it's permanytely wet!
Si
ok the best would have been to lay it into the wet screed but even then you are taking a big risk laying marble out side in the uk you could not be using a worse tile .it will take in water crack and faid in no time the question you should be asking how can i seal this against the uk weather.the faiding you cant .but the water ingress you stand a chance very little over time .you need to tell them that marble is not for out side use in the uk
Sporty,
Sporty,
Sporty,
Sporty,
