Guest viewing is limited
Discuss therma coat in the UK Tiling Forum area at TilersForums.com.
mikethetile
had a look , its the same as the thermal coatings used to reflect heat back into the room. someones had the bright idea of repackaging and remarketing
to reach the the same thermal capacity as boards you have to give multiple coats, and that could be a lot of coats
cost of material
time spent on application
drying times between coats
down time on site
its all cost implications and just how do you judge how many coats equell a board, everyone applies at different thickness
Reply to therma coat in the UK Tiling Forum area at TilersForums.com
Hello, I did some reading here and there, but the opinions seem to diverge at some point and I...
therma coat
