Discuss Thin Cuts / Slithers in the Australia Tiling Forum area at TilersForums.com.
padtheplumber
583
redditch
Hi guys
I was wondering what the general consensus is when setting out - do you avoid slither cuts like the plague, or are they just part and parcel of the job sometimes and you don't worry about it?
As an example if you had a fairly standard bathroom, decent size ceramic tiles would you be happy to leave a thin cut (30mm) in a corner over a bath so you could start full tile from a window or would you look for another option?
Just curious to see what your opinions are on a situation like this.
Cheers
Mart
Hey Mart, (ah ha! I got ur name now!:D)
This 30mm cut, is it on the window wall?
Is it near the window?
Pic may help if u have one.
Thing is, on entering any room our eyes are always drawn to the biggest light source first, so if u have any small cuts in the vicinity of the window these will be magnified.
So for me if I have to compromise with a small cut for any reason I do my utmost to hide it in an opposite corner or behind a door.
Probably don't help your setting out much tho haha
padtheplumber
583
redditch
Cheers guys,
Maybe I could ask the question in a different way;
If starting full tile from one side of a window (which means a bit less cutting) would leave a 30mm cut into the corner of a wall over a bath (on the same wall) would you start here if there was another option which left better cuts into the corners, but meant more cut tiles around the window?
Just trying to gauge whether you would rather have less cuts around the window, but a thin cut in one corner, or more cuts around a window but a bigger cut into a corner,
or does a thin cut not worry you either way?
thanks again
Mart.
Dan
Admin
Staff member
5,094
1,323
Staffordshire, UK
Setting out is always key. If you ended up with a 30mm cut at the top of the window, pull it down 30mm so it's a full tile and then check everything else to see how that's effected. If it leaves 30mm somewhere else, pull it down another 30mm so you're now full tile on that (the bath or floor or whatever) and cutting 30mm off the tile above the window.
If that then leaves 30mm above something else, pull it down again.
You need to check the level of everything too because you want full tile on the lowest point of the floor, as full tile on the highest point is going to leave a slither on the lowest point.
So you go in a room with a level and marker / pencil first. Then your tile guage staff. Then your tiles.
Actually you probably go in with other stuff first to make everything good for tiling. But that's the order you go in when that's all prepared.
It makes life a lot easier when you've planned it all well.
Makes a change from going in with a pipe bender and gas gun eh? Hehe
padtheplumber
583
redditch
Thing is, I've done my own tiling for quite a few years, but I've been off work with an injury for 6 weeks, so I've had to employ a tiler for my last few jobs.
Now, I am really happy with his work, he's done a couple of lovely floors for me, he's quick, tidy, cracks on with it which is great, but on a bathroom this week he has done what I described above, full tile from one side of window leaving a slither on the corner where the bath is.
He had only got 5 tiles on when I popped in to see him, so we agreed on a different set out on that wall.
I was, however, wondering if I'd been a bit harsh about it, thin cuts / tramlines in corners, especially wet areas, have always been something I've personally disliked, but that doesn't necessarily mean its wrong, so I thought I'd get an opinion for some of you fine fellows!!
Cheers
Mart
Cheers
Mart
So u mislead us Mart! :( *shakes head with disappointment!*
padtheplumber
583
redditch
Sorry, it was unintentional if it comes across like that. :disappointed:
I was trying to avoid it sounding like a rant or a having a go type thread, thats not my style at all. I was just wondering how some of you trained / time served guys judged those type of decisions that we all have to make on the job - i'm a plumber who's picked up tiling (amongst other things) along the way.
Tiling is one of my favorite parts of the work I do, but at the moment I can't do it, so this is something I've not come across before.
Appreciate the input
Mart
:smiley:
Mart
:smiley:
Hahahaha Mart was just pulling your pipe bender!
I'd never publicly offend someone intentionally!
I'd send a PM! :D
Reply to Thin Cuts / Slithers in the Australia Tiling Forum area at TilersForums.com
Hi, 1200 wide tray and tiling shower enclosure recess with metro tiles where the 1200 wide...
Hello! We have an issue with 12 cracked large format thin porcelain tiles (1500x1500x6mm). They...
Hi I've been a 'tiler' for a very long time but in the last 10 years moved into maintenance and...
Hi. I'm relatively new to tiling, and have begun offering it as a service alongside my existing...
5K
I was quoted over £4700 (inclusive of VAT) to rip out and replace my bathroom. This does not...
7K
padtheplumber
redditch
Business Name
G C Plumbing
    Votes: 13 8.8%
    Votes: 11 7.5%
    Votes: 44 29.9%
    Votes: 17 11.6%
    Votes: 35 23.8%
    Votes: 20 13.6%
    Votes: 15 10.2%
    Votes: 7 4.8%
