Discuss Thoughts on this in the Canada Tile Advice area at TilersForums.com.
Gazzer
A while back I went to quote for a floor. The substrate was 18mm ply on joists. Very solid and no problem except they wanted backerboard, UFH and Travertine or limestone...maybe polished marble. The first thing I noticed was 4 doors were too low and You wouldnt be able to get the depth needed.
Adjusting the doors is a no go as one door is a folding door , about 2 metres wide. The others are UPVC and to adjust would be major work.
They left it at that . I now have an email stating that a "builder " will remove the ply and cut it into the joists, thereby giving an extra 18mm.
This will still be overboarded with backerboards but I am not too keen on the idea. In theory it may be fine but until I see how well this "builder" is then I dont feel I can give a definite answer.
How would you play it ?
I
Ian
I suppose in theory if extra noggins were added 18mm below finished joist height, with battens, to support the ply, it may work. I suppose you would have to see what the deflection was like after this was done. As Doug says, it would surely be under strength as there would be continuous breaks in the substrate, essentially all this would be doing would be in filling the joists.
Ajax123
1,213
Lincolnshire
I don't think weakening the floor would be too much of a concern in this instance. If they were taking lumps off the joists then yes but just in filling is not really much of a worry for me.
of greater concern would be the level of movement in the floor. Bear in mind that the joists will move at a different rate to the ply and if it is cut in really tightly it will try to belly when heated.
With trav this one sounds fraud with danger.
Reply to Thoughts on this in the Canada Tile Advice area at TilersForums.com
I am sure someone will know a good practice solution. We started a wetroom last year and then...
Hello all, I am planning on tiling my bathroom floor, I removed the old tiles myself which were...
Hi all, new to the forum, I'm a customer of a bodged tiling job done 2 years ago by a general...
Thoughts on this
    Votes: 13 8.8%
    Votes: 11 7.5%
    Votes: 44 29.9%
    Votes: 17 11.6%
    Votes: 35 23.8%
    Votes: 20 13.6%
    Votes: 15 10.2%
    Votes: 7 4.8%
