Guest viewing is limited
Tiling Tool Suppliers
Discuss tile cutter in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com.
georgetknight
i use one mate good cutter for angles but takes a bit of getting used to as you cant see the scoring wheel i have the piuma 43 but i also have the rubi ts700 for the bigger tiles which also does the angles. they are an italian company brevetti montolit i also use their nippers and their diamond hole cutters if it were a choice i would say rubi rubi rubi as the kaiser cheifs would say sorry ***** humor.
Reply to tile cutter in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com
Plazma cutter causing SPD failure?? Discussion ThreadPlazma cutter causing SPD failure...
Currently using TX700N but obviously now too small for the 1200x600mm I'm increasingly being...
Hi all Can anyone recommend a cutter for herringbone, got 200m2 of 300x150 walls to do in a few...
Popular Tile Cutter Threads
tile cutter
    Votes: 5 5.9%
    Votes: 6 7.1%
    Votes: 5 5.9%
    Votes: 22 25.9%
    Votes: 13 15.3%
    Votes: 25 29.4%
    Votes: 3 3.5%
    Votes: 2 2.4%
    Votes: 18 21.2%
    Votes: 14 16.5%
    Votes: 6 7.1%
    Votes: 5 5.9%
    Votes: 3 3.5%
