cosycarb
Hi
I'm doing a little diy tiling and need to ask about the best way to do corners with the plastic tile edging. I don't have a problem with a window with the 45 degree cuts to make a square edge. The real problem I'm having is a wall that is half tiled and goes around into the window. This means I need to cut the top tile edging as normal and the upright piece from the sill to the top edging (am I explaining this right:mad2: )
Can someone tell me how to do this without the point of the top edging sticking out over of the upright edging. Will i have to trim the "point" of the top edging to match the thickness of the vertical edging. which means this will leave a hole to fill with grout, but doesn't look the best.
Many thanks for any help received
Regards
Steve
Regards
Steve
