Discuss Tile grout blown, tiles easily lifted up. what's the problem? in the Tile Adhesive and Grout Advice area at TilersForums.com.
Hi,
I have numerous problems with tiles laid about four months ago.
Problems include:Grout coming up; tiles moving up and down; hollow sound when you step on a tile.
I lifted a tile. It came up very easily - in one sharp blow of a hammer! Underneath is tons of grey stuff that has cracked - presumably the glue.
What has happened? Has the glue not worked ?
What should i do to rectify this problem?
Thank you for any advice.
Brendan
Blunt Tool
Looks like the adhesive was already too dry as it has not bonded onto tile or ply. Best to take up floor, if tiles all come up like that they can be used again just clean edges. Give sub floor a good coat of SBR bonding, and a bag of slow set flexible S1 cement based adhesive ( Mapei etc ) from your local tile shop. Grout with a flexible grout
Many thanks for your replies.
You could be correct about the possibility of damp. We are having to install a damp course into the adjacent walls in the front hallway. Dampness runs half way up the walls.
Saying that, the joists and noggins weren’t damp when the tiles were installed.
Plus, the builder used cheap plywood. Some of it (6mm) went onto floor boards. The remainder was 18mm ply where they were no floorboards.
Is it just damp that would cause the adhesive not to bond to the tile or ply?
Some recommend I don’t use plywood. Do you agree?
What does SBR bonding do (in layman’s simple terms!)?
One Day
To answer your original question though, how to rectify it. It all needs taking up. Replace the ply with something stronger that's not 6mm ply. if you've damp issues, I'd suggest overboard the floor with 10mm wedi board. Or ditra membrane.
And most important, get a tiler in who knows how to prepare properly!
Bond
528
Highland
SBR, is a primer and admixture , which increases bond strength and flexibility.
Reply to Tile grout blown, tiles easily lifted up. what's the problem? in the Tile Adhesive and Grout Advice area at TilersForums.com
  • Sticky
5K
Matthew7
I started removing the tiles in my bathroom today and the majority of the plaster has come off...
Tikkaaa
Hello! At the completion of my new kitchen tile installation, the grout I had selected (dark...
Tile Adhesive Trending Topics
London
Business Name
None
    Votes: 7 5.2%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.9%
    Votes: 16 11.9%
    Votes: 33 24.4%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.8%
    Votes: 18 13.3%
    Votes: 15 11.1%
    Votes: 7 5.2%
    Votes: 3 2.2%
    Votes: 3 2.2%
