Tile layout thoughts
Hi,
First time setting out tiles, so I've drawn out a bit of a plan. I was hoping someone with a bit more experience could share any thoughts.
Fairly happy with the horizontal layout. The backdoor has a really thin strip just infront of it, but it's not easy to avoid. I'm wondering whether to put an inset doormat there since I'm putting one by the front door due to low clearance.
Tiles are 600mm by 400mm and I'm planning on using 6mm tile spacing.
Any thoughts welcome. Thanks
Yeah 6mm is massive. Half it.
Also row g is a bit thin by the worktop island and if you shifted it all 'up' by that slither amount I can't see it effecting anything else. I'd maybe consider doing that but it looks fine otherwise.
Ps love the CAD. What software did you use?
Thanks for the tips guys.
I halved the grout lines to 3mm.
I used design software called Figma. It's not really suited to this, it's for web design really, but I'm familiar with it and it's free to use 🙂
James3857,
James3857,
James3857,
James3857,
