Sharkysharky
Hello chaps !
Please forgive me if this is a simple problem but I'm a newbie and this is the first proper tiling job I've ever attempted.
I'm tiling my bathroom and the vertical tile lines line up pretty much perfect either side of the border (the bottoms grouted, I'm currently tiling the top), apart that is, from the one vertical column I'm working on, the right hand side of the tile on top is well over the right hand side of the grout line on the bottom below the border. It's almost as if this particular row of tiles is slightly wider than the other tiles. The left hand side of the column match up fine. Have I dropped a clanger somewhere ?
As far as I can see I've got 2 options, take that particular column off and try again, or ever so slightly sand down the right hand side of the top column to bring it back into line with the same point on the bottom of the border. It'll be about 4 mm slimmer but I don't think it will be noticable. Any ideas from the pros ? Thanks I really appreciate it:mad2:
