Stewart
Also tell the builder that it's cheaper to supply weber standard set addy and it goes further.....
- Sent from iPhone.....
hello,not one i would like to take on but if you are going ahead with this why dont you take his tubbed gear hes supplying and use it on another more suitable job later and you supply some cement based adhesive,might make you feel a bit more at ease about the job and wont burst your bank either?
hope it works out for you
Wotcha guys, hope everyone's well and business is good.
Right. Tile on tiles. Yeah I know what you're thinking, don't do it. That's what I said to the project manager when he first asked but we talked a bit more and it turns out he's got four other big jobs on the go and well it got my attention so I said I'd have a look. Begrudgingly though, I wasn't keen. Anyway I've had a look and the wall is skimmed plaster, in good nick it seems. Tiles on it are wafer thin 150 square, well attached, good addy (looks like Ardex x77w) and the grout is good, no cracks or anything. I said that really it should be ripped down but there just isnt the money etc. Figured if I don't do it someone else will and hey times are hard.
Oh yeah forgot to mention they're supplying the materials. It's some nicobond addy, never seen it before. And it's tubbed.
So water dispersion addy, on existing tiles, on skimmed plasterboard. I know what you're all thinking, it doesn't get much worse than that.
I've given him the technical details and argued this way and that but there is no convincing him. So gonna crack on.
My intention is to firstly score the existing tiles up with the grinder. This obviously is to give something for the gear to lock on to and also to expose the biscuit a bit which I'm hoping will help the gear to set.
Then wash it down with sugar soap to clean up the left over glazed faces.
Then i'm gonna painstakingly batten everything (wood bit, ceramic bit, plug, screw, tap tap, drill)
Then I'm gonna tile. Thinking 8mm trowel, was thinking about maybe ten (new tiles are 300 x 250) but then thought that that's gonna make the set even slower? As in more water to disperse as it were?
Then i'm gonna leave it for about three days while I do the kitchen and another toilet
And then grout, pick up my cheque and walk out the door feeling ashamed, used and kinda dirty!!
Anyway you're an opinionated lot, what do you think?!
The weight comes to just under 30k. Anyways you lot are right, I can't do this and walk away callIng myself a tiler. Two of the Walls are actually block work, stripping one of them back and priming going on with a big trowel to pick up the holes and stuff. The other one of those is in good nick so priming that with p82 and going on it and the plasterboard is coming down, 12.5 marmox up and tiling. Gonna use the nicobond on the wedi and the block and gonna use powder on the final wall. It's all coming out of my pocket. Oh well, call it my good deed for the month!! Thanks to everyone for not letting me do this, dave you clinched it, you're so right. Another job with no money in it!!! Considering giving up on life and going to work in an office. Nah just kidding, would miss you lot!!Anyway I've had a look and the wall is skimmed plaster
It's not skimmed it's plasterboard.
