Discuss Tile onto Plasterboard ?? in the British & UK Tiling Forum area at TilersForums.com.
AliGage
Subscribed
4,531
1,188
Peterborough, England
It would depend for me on what adhesive and therefore the size and type of tile i'm fixing. I would not use tubbed adhesive onto fresh plasterboard. I've found what little moisture there is in tubbed adhesive gets sucked into the paper of the plasterboard whilst drying. You may then find some tiles don't even bond to the wall. Which is why if you go and de-tile a bathroom that's in a house built in the last 30 years you'll find the tiles will fall off the wall leaving most the adhesive stuck to the wall. If you were intending on using tubbed adhesive i'd prime the wall with BAL Primer (or an equivilent).
Personally though i'd use a powdered adhesive. It's loads cheaper, easy to mix and work with, and you can mix it up that little bit thicker when across the top of your window and in the top reveal.
Thta's what works for me anyway, hope it helps.
Reply to Tile onto Plasterboard ?? in the British & UK Tiling Forum area at TilersForums.com
Seems alot of talk that 20kg per mtr2 is the max weight limit for plaster. Few questions 1. its...
    • Useful
Hi, Im looking for a recommendation for a liquid tanking. I have to use a liquid tanking...
Some helpful advice/opinion would be appreciated... Existing tiles on walls, some of the walls...
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
