Chris_911
I'm about to start tiling my bathroom project. Tiles are 600 x 300 porcelain to be laid 'landscape' and in vertical columns (NOT brick bond). There is a also a narrow band of marble mosaic that will be about 2/3 of the way up the wall.
I've spent a few hours today assessing the setting out. I've settled on having my horizontal tile centreline for the end wall (with the shower) coincident with the centreline of the bath and where the shower valve is mounted. I've assessed vertically as well and got something that avoids tile slivers.
My question concerns whether the tiles look better if they follow round corners - what I mean is, where there is a portion of the tile on side of the corner should the remainder follow around the wall on the other side of the corner?
One of the reasons I ask is that the wall above the bath (long side) is 1.8m which clearly falls nicely with 600mm long tiles - I will have almost a whole tile at the one end, or both if I centre.
As it stands on the shower wall (bath end) I will have 80mm of tile length going into the corner with this wall and the wall with the long side of the bath. Will it look odd if I start with a whole tile? If I use the remaining portion of the tile (600-520) I will end up with a portion of tile slightly less than 80mm at the opposite end of this wall.
What looks best?
I hope my explanation makes sense, and hence my question. I've attached a few pics of the room as it stands.
Thanks in advance.
What looks best?
Thanks in advance.
