minesapint
Hi, what size tile spacers should I use? I am putting some tiles in an enclosure, I read some where 3 or 4mm would be best as easier to grout.
I will be using different tiles on the rest of the walls, should I use the same size spacers so grout lines are similar?
Also for the floor tiles what would you recommend?
