Guest viewing limit reached
Tile spacers
Both H&R Johnsons and Pilkintons had lugs on the tile side for spacing. They then went to a sloped edge for spacing but of course this went against the principles of a joint so you still had to space them. Apart from matchsticks etc Homelux marketed the punched out plastic from their tile trims as spacers.
It was only when the continental tiles became popular that spacers made an appearance.
I use 2mm on walls and 3mm on floors, both depend on the quality and regularity of size of tile though.
Always use 3mm on planks on floor, although was asked to use 4mm on my last job, and looked really good with dark grout, helps with bowed tiles too.
Always 2-3 on walls and 4-5 on floors. I think best to have the 4-5mm on floors incase one loses the grout line somewhere , and losing it a mm here or there won't be as noticeable with the larger spacer's.
Tile spacers
Ben Ross,
average,
Ben Ross,
average,
