Tiling Tool Suppliers
Discuss Tile Tiling Machine Vibrator Suction Cup For Ceramic Floor Paving Leveling Tool in the Tiling Tools area at TilersForums.com.
E
eBay
Product parameters: Voltage: 220v 50HZ Input voltage: 21V (charger plug can be customized) Rated power: 120W Battery capacity: 10000mAh Charging time: about 4 hours Vibration frequency: 0-120HZ/S Vibration speed adjustment: 6-speed adjustment Suction cup diameter: 120mm (4.72 inches) Adsorption weight: 380kg (837.76 pounds) Applicable tiles (the length of the entire tile): 60-150cm (23.62-59.06 inches) Head shell material: engineering grade plastic Vibration plate material: aluminum alloy Body handle: PA6 Packing size: 34.00 x 26.00 x 19.00cm (13.39*10.24*7.48 inches) Gross weight (one battery and one charge): 2.4kg; (5.29 pounds) .
Continue reading...
Reply to Tile Tiling Machine Vibrator Suction Cup For Ceramic Floor Paving Leveling Tool in the Tiling Tools area at TilersForums.com
E
Product parameters: Voltage: 220v 50HZ Input voltage: 21V (charger plug can be customized) Rated...
E
E
Description With 6 adjustable speeds, you can change the vibration frequency of this tile...
E
E
Tile Vibrator Suction Cup Professional Tiling Tools Machine Floor Laying Machine. 1 x Tile...
E
E
Features: 1. Powerful motor: the motor allows the tool to run cooler and 50 per cent more...
E
E
E
Tiling Tool Popular Threads
Tags
None
    Votes: 9 5.5%
    Votes: 17 10.3%
    Votes: 12 7.3%
    Votes: 46 27.9%
    Votes: 21 12.7%
    Votes: 39 23.6%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.5%
    Votes: 17 10.3%
    Votes: 8 4.8%
    Votes: 5 3.0%
