Tile Tiling Machine Vibrator Suction Cup For Ceramic Floor Paving Leveling Tool
E
eBay
Product parameters: Voltage: 220v 50HZ Input voltage: 21V (charger plug can be customized) Rated power: 120W Battery capacity: 10000mAh Charging time: about 4 hours Vibration frequency: 0-120HZ/S Vibration speed adjustment: 6-speed adjustment Suction cup diameter: 120mm (4.72 inches) Adsorption weight: 380kg (837.76 pounds) Applicable tiles (the length of the entire tile): 60-150cm (23.62-59.06 inches) Head shell material: engineering grade plastic Vibration plate material: aluminum alloy Body handle: PA6 Packing size: 34.00 x 26.00 x 19.00cm (13.39*10.24*7.48 inches) Gross weight (one battery and one charge): 2.4kg; (5.29 pounds) .
Continue reading...
Tools on eBay etc
eBay,
eBay,
