Discuss Tile Trim - Floor to wall - advice please in the British & UK Tiling Forum area at TilersForums.com.
mick7
tile trim floor to wall
Apologies.
I'm just about to start in the next couple of days, 60 x 60 tiles porcelaine on a 5 sq mt utility room floor. Bought alll the stuff thanks to the forum, but I also want to half tile the walls ( samller tiles. I thought a double edged tile trim( do they make one?) would make a neater job and prevent the cracking at the wall/floor joint as has already happened in a newly tiled bathroom - hence why I'm doing the job myself this time. Any advice welcome,thanks.
DHTiling
CTD do internal corner trims..( homelux or schluter ) but are shut till wednesday...but wickes do a simlar one if you need it before hand..... [DLMURL]http://www.wickes.co.uk/invt/166083?htxt=6YwZAISW1i5OgIudElUVh4%2BI3KMD0YlK3aWM7EPIBJQVvJOxcInvY1H4JwBcSZ2MIfCIMv2VNq1z%0AWJ9bQPNXrg%3D%3D[/DLMURL]
DHTiling
This is the type you want...
but not all tile/diy shops stock them......
DHTiling
That one in the pic is a schluter one...
They make a few with different profiles and colours....
here's a link to the schluter dilex trim page...
You will be able to choose which one you require and get the code before you order ..
http://www.schluter.co.uk/141.aspx
Why not just use Silicon?
Silicon is good .YES.!!
But in can break down in time and needs replacing...
It's down to personal choice.. and costs...
I use both methods and both look fine.....:grin:
But only on floor to wall joints.. i just Silicon wall joints....
An ideal situtation for them is in wet rooms....
Reply to Tile Trim - Floor to wall - advice please in the British & UK Tiling Forum area at TilersForums.com
Hi all, We employed a tiler to lay some rectified wood effect planks in a herringbone pattern…...
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
