Discuss Tile Trim in the British & UK Tiling Forum area at TilersForums.com.
Alan.P
Maybe i'm reading it wrong!?! The way i see it, if you're cutting trim around a window, it would need to be layed in the mitre block. If you lay it against a wall ie. if you were only tiling to half room height, you'd stand it up in the mitre block.
I don't see the difference in where you lay it to, it depends onto which wall your going to lay the back of the trim / flange to, that determines what technique. Whether it stops half way up and stops at a 3 way mitre or a horizontal trims underside.
CJ
1,088
Somerset
Get a length of trade trim (less than a quid) and practice. Cut different mitres until it sticks in ya napper.
Or, do as I do.........buy 20 trims at a time.......so if and WHEN you make a mess of it........you got enough spares. When your paying for them, and your running low.....its surprising how quick it sticks in ya napper :hurray:
cornish_crofter
Now, lets move onto coving, there are FOUR different cuts..........!
External corners, left and right, and internal corners left and right.
Come to think of it there are about 6 different ways a tile trim can be cut, and that's assuming you've got nice 90° corners, not the 135° like I have in my bathroom. Try doing that in CTD metal tile trim with the corners they provide.
Reply to Tile Trim in the British & UK Tiling Forum area at TilersForums.com
There's a video on youtube of a guy templating for large format floor tiles, and I get the...
Hi, 1200 wide tray and tiling shower enclosure recess with metro tiles where the 1200 wide...
Tile Trim
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
