Discuss Tile trim in the UK Tiling Forum area at TilersForums.com.
F
FreeD
I remember reading another post where the discussion was whether you push the trim into the wall face or reveal...When I did my course at Nett I think we pushed the trim into the wall face...
Anyway I've got a job on at the moment and i've looked at the other bathrooms in the house and it looks like the tiler has done what many others seem to do on here which is push the trim into the reveal...
How is this done?...do u tile the face first...leaving the required depth for the reveals...then tile the reveals plus insert trim?
And do you have the edge of the trim that lips over the tile showing on the wall face or on the reveal?
K
Knackered Knees
Tiling is all about the finish, just take your time,measure twice cut once. then once you have one correct cut the rest the same. If the reveal is out of level then you may have to use more adhesive on one side of the reveal to pack up your trim. If the reveal is waaay out of level or plumb for that matter, you may need to prep this before tiling, to true everything up.
diamondtiling
Have a look at the picture, is that what you mean? The tile on the reveal (boxing in) is flush with the edge, the trim will then be fitted and the tiles fixed.
The picture is upside down for some reason but you can still see how the trim was fitted by looking at the end result.
Picture 70 of 79 from Bathroom refurb.
I
Ian
As has already been mentioned, tile the face wall first then put the trim into the reveal and tile the reveal. One of the reasons for doing it this way is that it is not always possible to get a trim that is a perfect depth for your tile, so you may have to pack the tiles out that sit in the trim, it is much easier to do this with a few tiles in the reveal than have to build out the whole face wall.
Reply to Tile trim in the UK Tiling Forum area at TilersForums.com
Tile trim
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
