Discuss Tile wedges... in the British & UK Tiling Forum area at TilersForums.com.
DHTiling
One of the best tiling aids there is...
Very useful to maintain that gap for Silicon joint around baths and shower trays and around wall to floor joints.
Does anybody use them ..?
If you have used them then Tradetiler will be happy to supply them to you..
0 - 5 mm Wedges x 500
What are tile wedges?
These will save you lots of time and therefore money. Used for wall tiling in situations when you are putting bottom cuts in above any uneven surface like rough concrete etc. Using bits of card board and tile nibblings is OK But takes ages. if nothing is used the tiles keep slipping, especially when they have a thick layer of adhesive on them. The trick is to use a wedge instead but obviously you can only insert it the thickness of a tile. Turning it to the side over comes this problem. (see 'in use' picture) Micro adjust the height up to 5 mm. Use on top of each other to go over 5 mm. Great for marble wall tiling where each piece varies slightly and standard spacers will not work REUSABLE
Bag of 500
Weight 240g
'in use' picture
Price: £3.49 £4.01 Including VAT at 15%
brian c
I used these yesterday for installing skirting board after I tiled a bathroom floor, I wanted to lift the skirting by just 1mm so when I come to paint I have just that little bit of play knowing the paint won't run into the grout.[/quote
i use masking tape....lol
Reply to Tile wedges... in the British & UK Tiling Forum area at TilersForums.com
Hi, 1200 wide tray and tiling shower enclosure recess with metro tiles where the 1200 wide...
Can I trouble some experts in here for some advice on laying pavers on a concrete pool surround...
Tile wedges...
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
